| tributary |
Mar 31 2005, 11:16 AM
Newbie ![]() Group: Members Posts: 11 Joined: 9-August 04 From: Las Vegas NV Member No.: 2,489 |
914 bored to 2.1 seems to run at 220 to 260 up hills even in cool weather...
should I be concerned or not.. would an oil cooler do much to help the problem and if so any recommendations? thanks John |
| SirAndy |
Mar 31 2005, 11:28 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,517 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) around 200 is a gud temp, above 220 is hot, above 240 is TOO hot ... couple of things to check: - timing - cooling flaps, make sure they're in the open position, which means the drivers side flap is up and the pass side flap is DOWN - make sure the cooling fins on the cylinders are clean. if not sure, take off the tin and check - make sure the oil cooler isn't plugged, on the outside with crud, or on the inside - what year is the car? if pre '73, get the rubber flaps that go under the car. they help cooling (when moving) if all that checks out OK, consider a front mounted oil cooler ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
tributary overheating Mar 31 2005, 11:16 AM
Dave_Darling Yes, you should be concerned. 260 is definitely h... Mar 31 2005, 11:23 AM
trekkor I've heard the synthetic oils can handle that ... Mar 31 2005, 11:25 AM
Joe Ricard Oil temps seem hot but are your gauges calibrated ... Mar 31 2005, 11:26 AM
SirAndy <... Mar 31 2005, 01:59 PM
Aaron Cox <... Mar 31 2005, 02:00 PM
Jake Raby Not with the DTM....
23.5" tire and oil has never ... Mar 31 2005, 02:13 PM
mudfoot76 So what types of CHT monitoring are people using? ... Mar 31 2005, 03:02 PM
Jake Raby VDO is the standard gauges used by most.
I like t... Mar 31 2005, 03:21 PM
D-Jet Sorry, I'm really a noob. I have a stock ... Mar 31 2005, 03:28 PM
Rand A guy brought a VW into my Dad's shop complain... Mar 31 2005, 06:56 PM
Dave_Darling Mar 31 2005, 07:20 PM
Jake Raby Dirty cooling fans can also make for hotter temps.... Mar 31 2005, 08:19 PM
D-Jet Great advice. Thanks guys. Looks like some new gau... Mar 31 2005, 08:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 09:51 PM |
