Wire your 220V welder, How to guide. Bondo, look! |
Series9 |
Mar 31 2005, 01:24 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
I had to move the outlet for my welder today. Since it's been a topic of recent discussion, I decided to document the event.
I went to Home Depot and purchased the correct length of 8-3 stranded cable and then ran it through the attic after drilling holes to drop it down to the main panel and the wall where the outlet would go: Attached image(s) |
Series9 |
Mar 31 2005, 05:03 PM
Are you just looking for something to bitch about? If you can explain how there is a single difference, as far as safety is concerned, between this and punching a pop-out of the top of the box and running the cable up the wall cavity where someone can put a screw through the drywall and into the cable, I'll go rewire the whole fucking thing. I said before, clearly, that I will be removing this cable when I move. I am completely unconcerned with an inspection. This is absolutely, 100% as safe as running the cable through the top of the main box and up the wall cavity. I swear to god, some of you guys could bitch about a day off work. |
Lo-Fi Version | Time is now: 13th June 2024 - 11:37 PM |
