Plug gap setting with MSD 6 ?, Technical help and opinions please - |
David Mueller |
Mar 31 2005, 08:21 AM
Member Group: Members Posts: 79 Joined: 4-February 03 From: Calgary, Alberta Canada Member No.: 236 |
I've a '74 2.0+ runing a set of 44 Webers - MSD dissy and MSD6 control box - and I wanted some help with set up - I've been reading here about what people recommed for set-ups and I wanted some more opinions which on this site should be easy to get...
I'm running NGK BP5E S Plugs currently gapped @ 0.40 is that about right ? Webers - 36mm venturies - F11 - 140 Mains - 200 A/C - 55 Idles Main fuel inlet needle jet is a 175 - I've tried 50 idles any they don't work well on the fuel up here in Canada - I live in Calgary AB which is about 4500' - 6500' depending on the weather... I've seen people saying they are runing about 12 degree initial timing with a 29 max advance timing - I haven't changed out any springs or bushings in the MSD dissy yet..Most people are running the mallory when you put int he grey/grey springs what kind of a torque curve does that give you as I can match with the springs form the MSD - is the grey/grey combo the fastest spin up / medium etc... Any help would be appreciated... Other info on the car if it's needed - 96mm big bore kit from EBS racing -, aux oil cooler, high output oil pump, CB perfromance hex bar linkage, MSD Blaster 2 coil with 8mm Jacobs leads, Help anybody ? |
David Mueller |
Mar 31 2005, 10:09 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
Only one opinion...that's not what I expected... |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:29 AM |
