> Engine Compartment Hinge, Broken off @ body... OPTIONS??
Bimmerboy71_02
post Apr 1 2005, 09:10 PM
The engine compartment hinge on my buddies' 914 broke off a long time ago, and I am finally able to get around to fixing it. Is there an easy solution to fix this? Welding is almost out of the question since the two halves of the hinge barely match up; like there's metal missing. Just hoping you guys could lay all of my options out.
(IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif)
Ryan
rhodyguy
post Apr 2 2005, 01:49 AM
if it came completely off the body you're in luck. you don't have to remove the carcass. you need to take the rear deck off , take the spring off the roller(hinge in the up position- slide a 10(?) mm deepwell socket w/an extention over the end of the spring and lever it down and off to the side with the extension), and remove the hinge on the bad side. pretty simple. the old pivot should leave witness marks so you know where to place the new one. there is a center bolt that retains the hinge arm on the pivot. you will get a new bolt when you buy a replacement pivot. al blose is coming by tomorrow and we'll be doing a few things on his car you might find of interest. stop by if you're interested. i'm sending you a pm. jwest engineering sells the part your buddy needs. look in the "resources, parts, and products".
kevin
Bimmerboy71_02   Engine Compartment Hinge   Apr 1 2005, 09:10 PM
StratPlayer   You need to post this question in the 914club gara...   Apr 1 2005, 11:26 PM
Aaron Cox   moving.....to garage   Apr 2 2005, 01:06 AM
skline   Need a picture to help us see what you are talking...   Apr 2 2005, 01:22 AM
lapuwali   Fabrication and welding are basically the options....   Apr 2 2005, 01:47 AM
rhodyguy   if it came completely off the body you're in l...   Apr 2 2005, 01:49 AM
neo914-6   Kevin, I believe you are talking about the deck li...   Apr 2 2005, 02:52 AM
914GT     Apr 2 2005, 09:20 AM
Eric_Shea     Apr 2 2005, 09:22 AM
neo914-6   ...   Apr 2 2005, 11:59 AM
lapuwali   The engine lid hinge is weak, as is the trunk lid ...   Apr 2 2005, 12:26 PM
bd1308   ...   Apr 2 2005, 02:54 PM
Eric_Shea
  Apr 2 2005, 07:27 PM
rhodyguy   i'm a fool. http://www.91...   Apr 2 2005, 08:18 PM
serge914   Mine is also broken on the passenger side. I am q...   May 2 2005, 07:48 PM
bd1308   can one see the broken areas when the engine lid i...   May 2 2005, 07:50 PM
Mueller     May 2 2005, 08:04 PM
SGB   http://www.914world.com/bbs2/html/...   May 2 2005, 08:08 PM
Mueller
  May 2 2005, 08:12 PM
lapuwali   It SO accessible, in fact, that I'm considerin...   May 2 2005, 08:14 PM
echocanyons   Let me tempt you with AA's part for this AA...   May 15 2005, 01:15 AM
Verruckt   I've seen the shock kits for the hoods (camp91...   May 15 2005, 02:18 AM
- Lo-Fi Version Time is now: 11th July 2025 - 07:26 AM
