> Engine Compartment Hinge, Broken off @ body... OPTIONS??
Bimmerboy71_02
post Apr 1 2005, 09:10 PM
The engine compartment hinge on my buddies' 914 broke off a long time ago, and I am finally able to get around to fixing it. Is there an easy solution to fix this? Welding is almost out of the question since the two halves of the hinge barely match up; like there's metal missing. Just hoping you guys could lay all of my options out.
(IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif)
Ryan
Eric_Shea
post Apr 2 2005, 09:22 AM
PMB Performance
welding near the engine gets risky and not everyone has the equipment
Well "Duhhhhhhh" Felix. This is exactly why he needs to go out and purchase four jackstands. Remove the engine and tranny. Check behind the backpad for rust on the floor. Remove the interior. Pull the peeling sail panels off. Remove the bumpers and check for rust there. Call Jake and get on the list. Pull the wheels. Pull the suspension. Send the suspension off for powdercoating. Get new bushings. New shocks are now in order. that powdercoated suspension looks so good you can't bolt it on that car. Fix all the rust spots. Ohhhhhhhhh... don't forget to weld the engine lid hinge. Bare metal repaint. Call Morph for some nifty interior pieces. Do a five-lug conversion. I know someone who can get you some brakes. Rennshifter (get on the list for that now as well...) Bolt it back together and enjoy your retirement. (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)
But I digress. Welding is just about your only option. Luckly, you're two 10mm bolts away from getting the lid off which is something you can do in the parking lot of a good welding shop. Have someone that knows what they're doing with a MIG (the welder, not the jet) fix'er up. You should be back on the road in 30 minutes. Make sure they lay a welding blanket over the engine.
Bimmerboy71_02   Engine Compartment Hinge   Apr 1 2005, 09:10 PM
StratPlayer   You need to post this question in the 914club gara...   Apr 1 2005, 11:26 PM
Aaron Cox   moving.....to garage   Apr 2 2005, 01:06 AM
skline   Need a picture to help us see what you are talking...   Apr 2 2005, 01:22 AM
lapuwali   Fabrication and welding are basically the options....   Apr 2 2005, 01:47 AM
rhodyguy   if it came completely off the body you're in l...   Apr 2 2005, 01:49 AM
neo914-6   Kevin, I believe you are talking about the deck li...   Apr 2 2005, 02:52 AM
914GT     Apr 2 2005, 09:20 AM
Eric_Shea     Apr 2 2005, 09:22 AMneo914-6   ...   Apr 2 2005, 11:59 AM
lapuwali   The engine lid hinge is weak, as is the trunk lid ...   Apr 2 2005, 12:26 PM
bd1308   ...   Apr 2 2005, 02:54 PM
Eric_Shea
  Apr 2 2005, 07:27 PM
rhodyguy   i'm a fool. http://www.91...   Apr 2 2005, 08:18 PM
serge914   Mine is also broken on the passenger side. I am q...   May 2 2005, 07:48 PM
bd1308   can one see the broken areas when the engine lid i...   May 2 2005, 07:50 PM
Mueller     May 2 2005, 08:04 PM
SGB   http://www.914world.com/bbs2/html/...   May 2 2005, 08:08 PM
Mueller
  May 2 2005, 08:12 PM
lapuwali   It SO accessible, in fact, that I'm considerin...   May 2 2005, 08:14 PM
echocanyons   Let me tempt you with AA's part for this AA...   May 15 2005, 01:15 AM
Verruckt   I've seen the shock kits for the hoods (camp91...   May 15 2005, 02:18 AM
- Lo-Fi Version Time is now: 11th July 2025 - 07:30 AM
