Which motor for future turbo?, my first post. |
sgray944t |
Mar 31 2005, 09:53 PM
Newbie Group: Members Posts: 19 Joined: 19-March 05 From: Raleigh, NC Member No.: 3,784 |
Well first I will introduce myself as this is my first post. I live in Raleigh, NC and have decided to build up a 914. My dad has lots of experience with Porsches of all types and suggested a 914 as a relatively simple and very fun car. I have been reading this site for a few weeks religously trying to learn everything I can. Im buying a 914 with the intent to swap a 911 motor in it. I am mainly interested in the 3.0 or 3.2 conversion, eventually to turbo. This is where my question comes into play. I have read Iamchappy's thread about turboing his 3.0 motor, and it seems like the 3 liter has no problems accepting boost. However I havent come across anything about turboing a 3.2. Is there any mechanical reason for this, or is it just something no one has documented? The reason I ask is that I am probably going to install the motor in its NA form first, then gather the parts for turbo over time. I think the higher hp of an NA 3.2 would hold me over until its time to turbo, however if turboing 3.2 motors is not ideal, and the 3.0 is a better forced induction motor, I would rather stick with it. My final goal is somewhere around 300hp give or take. At this point I'm thinking that the 3.0 is the better choice because its been turbocharged more often than the 3.2 and therefore I will have more support when problems arrive. Im also fairly sure the 3.0 can give me the power goals I'm looking for relatively easily. But please enlighten me, Im still learning about this 914 thing so I can use any comments you might have. Thanks alot guys!!!
Qarl |
Apr 3 2005, 07:18 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Its not as expensive as others would have you believe. If you can do a little welding or know someone who can, it can be done for less than a PMO carb conversion.
The silicone intake boots that replace the stock rubber one that ties the cis intake plate and the throttle body are the tough ones, I am considering making some using silicone and aluminum sometime in the future, The ones I am using are from a BAE kit, if you can find the old bonnets from a kit, the rest is actually pretty straight forward but you will have to do your own fabricating like I have. Even a low boost 3.0 sc engine is quite a thrilll. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
