Which motor for future turbo?, my first post. |
sgray944t |
Mar 31 2005, 09:53 PM
Newbie Group: Members Posts: 19 Joined: 19-March 05 From: Raleigh, NC Member No.: 3,784 |
Well first I will introduce myself as this is my first post. I live in Raleigh, NC and have decided to build up a 914. My dad has lots of experience with Porsches of all types and suggested a 914 as a relatively simple and very fun car. I have been reading this site for a few weeks religously trying to learn everything I can. Im buying a 914 with the intent to swap a 911 motor in it. I am mainly interested in the 3.0 or 3.2 conversion, eventually to turbo. This is where my question comes into play. I have read Iamchappy's thread about turboing his 3.0 motor, and it seems like the 3 liter has no problems accepting boost. However I havent come across anything about turboing a 3.2. Is there any mechanical reason for this, or is it just something no one has documented? The reason I ask is that I am probably going to install the motor in its NA form first, then gather the parts for turbo over time. I think the higher hp of an NA 3.2 would hold me over until its time to turbo, however if turboing 3.2 motors is not ideal, and the 3.0 is a better forced induction motor, I would rather stick with it. My final goal is somewhere around 300hp give or take. At this point I'm thinking that the 3.0 is the better choice because its been turbocharged more often than the 3.2 and therefore I will have more support when problems arrive. Im also fairly sure the 3.0 can give me the power goals I'm looking for relatively easily. But please enlighten me, Im still learning about this 914 thing so I can use any comments you might have. Thanks alot guys!!!
ArtechnikA |
Apr 4 2005, 05:20 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
while y'all are working on intake and exhaust manifolds (stock HE's won't live long with the heat, and headers although better, especially thermal coated, are still highter-gauge and different metal than the 830's...) don't forget the other parts that made the Turbo Carrera special -- the turbo scavenge oil pump that allows the low mounting position. the factory used the same nutating oil pump that once powered the torque convertor for the SportOMatic, driven from the and of a camshaft like an MFI pump.
when you go deciding where you're going to be mounting turbos, give some serious consideration to how you're going to get the oily foam out of the bottom of the turbo and back to - where? sump? oil tank? pick a place ... |
