TonyAKAVW |
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None ![]() |
I need to replace the front wheel bearings on my 70 1.7, as they are making noise, especially the driver's side.
I have a pair of rotors from my '73 car that I parted out about a year ago. They only have a few thousand miles on them and I have the bearings as well. I was thinking of just swapping them in for the rotors/bearings that I have now and I'd be done with it. However, I noticed that Pelican sells two different rotors, an early and a late. I'm wondering what the differences are, and whether I can use these rotors or not. Also, if the bearings are noisy is that a likely sign that the spindles are worn as well? -Tony |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
JR is right... they are NOT interchangeable... I tried this (only reverse... I tried fitting the pre-72 onto a 73+...
they do not line up right at all... you need the whole struts and everything... the good news is you can sell the good ones and recoup most of your cost... but, if all you need to replace is the bearings, you are only out around $20 as it is! |
Lo-Fi Version | Time is now: 1st July 2025 - 02:10 PM |
