> Early versus late front rotors
TonyAKAVW
post Apr 4 2005, 11:53 AM
That's my ride.
I need to replace the front wheel bearings on my 70 1.7, as they are making noise, especially the driver's side.
I have a pair of rotors from my '73 car that I parted out about a year ago. They only have a few thousand miles on them and I have the bearings as well. I was thinking of just swapping them in for the rotors/bearings that I have now and I'd be done with it. However, I noticed that Pelican sells two different rotors, an early and a late. I'm wondering what the differences are, and whether I can use these rotors or not.
Also, if the bearings are noisy is that a likely sign that the spindles are worn as well?
-Tony
lylegd
post Apr 5 2005, 08:14 AM
Tony, the early and late style rotors are not interchangeable unlesss you change almost everything (rotors, struts, calipers and the wheels, pads and possibly even the lug nuts.)
a) rotor/caliper/strut. The offset built into the design of the strut, caliper and rotor are different by roughly 1/8 inch.
(IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) The late style rotor has a hub centric flange cast into the area surrounding the outer bearing. This hub mates up to a machined hub centric hole in the late style mag wheels which assures the wheels are centered on the hubs. This is a very nice upgrade to your early car if you do it right, namely replace almost everything. You may even have to replace the lug nuts to make sure you are using a set that is right for your late style (mag) wheels. The mag wheels use a longer bolt.
c) I'm not certain of this item but it seems to me the later cars used thicker brake pads. Maybe someone else can chime in on this item.
d) The early style struts used a thru bolt to clamp the lower ball joint to the strut as well as a ball joint intended for use with a thru bolt. The later cars used a tapered pin arrangement that also used its own style of ball joint. Intermixing parts between early and late cars would be VERY dangerous.
I'm not trying to talk you out of this conversion but be sure to do it right. It is much more then just a rotor change.
Early would be the 70 thru 72 model years. Late would be 73 and up.
- Lo-Fi Version Time is now: 1st July 2025 - 01:16 PM
