> some six conversion issues...
meursault
post Jun 16 2003, 11:04 PM
Idjit Savant
So I'm test-fitting my engine and transmission in the car right now, and I'm having some problems. Perhaps someone can offer some advice.
Engine is a 2.7 liter, transmission is a 901 pull clutch, mount (for now) is a Patrick Motorsport piece.
Issue #1: supposedly the clutch cable to use is a 72-74 911 unit. The sheath is a little short, though, and making a bracket isn't necessarily easy because part of the crankcase prevents me from having a straight shot. I have an idea of how to do this, but I'm wondering if anyone's done this before. Here's a pic:
Steve
post Jun 21 2003, 11:04 AM
Meursault,
I'm very interested in trying this clutch assembly with my 3.2.
If I find a 70/71 trans all I need is the 70/71 throw out bearing and a 3.2 disk and pressure plate?
I looked in all my catalogs and they show a diferent disk and pressure plate for the 70/71 2.2 motor vs. the 72-86 911 engines.
What disk and pressure plate did you use with your 2.7?
Do you have the 911 part numbers?
When you put your trans on do you have to do anything special to get the throw out bearing to connect to the pressure plate?
The 70/71 trans conversion would be a lot less money than the 915 trans with the velios kit.
A 915 trans goes for $1500.00 plus the velios kit $1500.00 plus the shifter roughly $600.00.
All the 3.2 conversions I see out there with the 901 are using the KEP conversion.
The KEP conversion works great and the people and support at KEP are second to none.
But I still have problems with my clutch.
It feels like the clutch cable is stretching or the tube is broken.
I checked the clutch tube its been reinforced in three spots.
It's not going anywhere.
I replaced the weltmeister clutch cable with a factory six cable and that made a significant improvement.
I think my problem is either a bad KEP pressure plate which I doubt or the local machine shop machined my flywheel to thin and now the throw out bearing has to travel furthur to release the clutch.
I adjusted the pedal and stops for maximum throw.
I also did the KEP recommendations which is take out the washer behind the pivot ball and the modification of the throw out bearing fork tube.
I'm having to much fun driving my car to take it apart any time soon.
Some times I have to double clutch and I also have to make sure my seat is close enough to put the clutch pedal to the floor but otherwise its tolerable.
thanks for your help and good luck with your conversion!!!
Steve
meursault   some six conversion issues...   Jun 16 2003, 11:04 PM
meursault   Issue #2: Trying to find an oil line that will al...   Jun 16 2003, 11:07 PM
meursault   Trying a long, early oil hose was even less produc...   Jun 16 2003, 11:12 PM
meursault   Issue #3: I'm hoping this resolves itself wh...   Jun 16 2003, 11:19 PM
Steve   I ran the same conversion and used the stock 914-4...   Jun 17 2003, 12:08 AM
Steve   OOPs Sorry. I thought you were running the stock p...   Jun 17 2003, 12:16 AM
meursault   Hi, Steve! Nice car. Thanks for the suggestion...   Jun 17 2003, 12:26 AM
914Timo   Issue #1 Isnt that 911 gearbox ?? I mean the one b...   Jun 17 2003, 12:33 AM
914Timo   Ok, I saw now your last pic. Cutting the engine mo...   Jun 17 2003, 12:38 AM
elmonte   <...   Jun 17 2003, 12:46 AM
meursault   Hi, Timo! You're right. The transmission ...   Jun 17 2003, 01:13 AM
914Timo
  Jun 17 2003, 01:32 AM
meursault
  Jun 17 2003, 01:49 AM
914Timo   I am sorry I am nearly destroing your topic with a...   Jun 17 2003, 02:16 AM
meursault
  Jun 17 2003, 03:34 AM
scotty   Couldn't you just cut-n-splice a 90 degree ben...   Jun 17 2003, 09:47 AM
meursault   Scotty- Everything you see in that pic of the lin...   Jun 17 2003, 10:03 PM
meursault   More pics of my transmission:   Jun 17 2003, 10:12 PM
meursault   and another. Hope these answer any questions.   Jun 17 2003, 10:14 PM
Steve   That is a really cool conversion. I wonder if the ...   Jun 17 2003, 11:35 PM
meursault   Steve-- Do you still have that stock 914-6 hard r...   Jun 18 2003, 01:18 AM
FlatSix   People proposing to do a six conversion should rea...   Jun 18 2003, 06:10 AM
J P Stein   <...   Jun 18 2003, 02:58 PM
Steve   Sorry I sold all my stock oil lines years ago. Occ...   Jun 18 2003, 04:30 PM
meursault   For Karl et al: Here are some pics of sportomatic...   Jun 19 2003, 11:42 AM
meursault   Here's another:   Jun 19 2003, 11:43 AM
meursault   I thought I had a side-view pic of the flanges, bu...   Jun 19 2003, 11:47 AM
Brad Roberts   I'm playing catch up since I have been away fr...   Jun 19 2003, 01:31 PM
Steve   Meursault, I'm very interested in trying this...   Jun 21 2003, 11:04 AM
Brad Roberts   That pull assembly is not your answer. You'll ...   Jun 21 2003, 03:46 PM
Steve   I'm running there complete kit. 9" stage II wi...   Jun 21 2003, 03:51 PM
J P Stein   In his book, B. Anderson discribes the 70-71 clutc...   Jun 21 2003, 04:22 PM
Qarl   Rich J. is running a hydraulic setup in his 3.0 ca...   Jun 21 2003, 04:37 PM
Steve   Thanks for your opinions. Right now my 9" stage II...   Jun 21 2003, 04:44 PM
Qarl   Another thing to look into... The clutch pulley o...   Jun 21 2003, 05:06 PM
J P Stein   Steve: I wouldn't be too quick to change over ...   Jun 21 2003, 07:38 PM
Steve   They told me to remove the washer so I would get m...   Jun 21 2003, 08:47 PM
meursault   This is what I can say for the 911 pull clutch tra...   Jun 21 2003, 11:20 PM
Steve   Thanks for the reply!!! Let me know ho...   Jun 22 2003, 12:10 AM
meursault
  Jun 22 2003, 12:40 AM
Steve   I have another dumb question!! Can you use...   Jun 22 2003, 09:33 AM
meursault
  Jun 22 2003, 10:55 PM
Steve   Thanks!!!   Jun 22 2003, 11:50 PM
Brad Roberts   JP, The 9 inch clutch from Kennedy use a special ...   Jun 23 2003, 12:21 AM
- Lo-Fi Version Time is now: 1st July 2025 - 01:29 PM
