911 SC brakes, 19mm MC combo question |
RoadGlue |
Apr 4 2005, 10:46 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Hi everyone,
I've recently entered the world of bigger brakes, and hoped I could get some feedback here about proportioning valves. I have a set of 911 SC brakes ready to be mounted, and wondered if I'll get the correct brake bias by ditching the stock proportioning valve. I have the "T" fitting, but wonder if I shouldn't put an adjustable proportioning valve inline. Seems like it would always be better to have an adjustable proportioning valve, but is it absolutely necessary with that brake configuration? Mmmm, brakes. Thanks! Randy |
lapuwali |
Apr 5 2005, 03:53 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Adjustability is indeed a good thing, but the point being made here is adding an adjustable prop valve will generally not give you any useful adjustability. With stock /4 rear calipers and SC front calipers, the valve would be wide open and still too front-biased. Thus, there's no way to get proper balance with a setup like that, no matter how much you spin the adjuster, and a T is just as good as an adjustable prop valve. The only thing wrong with the stock 914/4 brakes is the calipers are heavy and the rotors are a bit undersized and not vented. Using most 911 calipers doesn't help the weight problem, and the non-vented rotors only seem to be a problem on the track. Using all stock (including the MC!) 914/4 parts with good pads, within everything in tip-top shape (rubber lines aren't swelled up, calipers aren't sticky, etc), I'd bet would be perfectly satisfactory for most people on the road. All too many people (including the DAPO with my car) have switched to 19mm MCs as an "upgrade", and now are hell-bent on adding bigger calipers, all to simply return the system back to the same hydraulic advantage it had with the stock MC. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:06 AM |
