DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Got the bad news yesterday. Geogg Bleyseng followed me to lunch from the AX and said "Blue smoke when you slow down, bad rings or valve guides".
I calmly say "Thanks I was wondered where all the oil was going". Meanwhile I'm thinkin "Aw $hit, more $$$". He says "Do a compression check then do another one after you squirt some oil in the cylinder. If it improves its bad rings if it doesn't it valve guides". I proceed to ask several questions that show how little I really know but, I got to thinkin about it last night at a wedding reception (damn this 914 thing is an obsession) and I think I understand it now. 2 ways for oil to get into the cylinder, past the rings from the crankcase and past the valve guides from the valve covers (from crankcase via pushrod tubes). On decel there is a high vacuum in the cylinder (and intake) therefore oil is sucked into the cylinder from one or both worn parts and burned leaving blue smoke from the exhaust and extra oil usage. Compression should be lower than desired because of leakage past the worm parts. Squirting oil in the cylinders will help seal the worn rings & cylinders and result in improved compression. But, if the valve guides are worn it will not help compression. Low oil pressure at idle results from more oil escaping at the bearings and therefor less oil reaching the sending unit at the oil cooler. Guess I'll do the compression checks Wednesday. More to follow. And I repeat "Ah $hit more $$$". Dave |
DNHunt |
Keep it up you guys are making me feel better all the time. Geoff, the vacuum when warmed up at idle, taken off of Megatune (the tuning software) is 41-46 kPa or 5.9-6.5 lbs/sq in. It doesn't move around much.
Still gonna do the compression checks Wednesday. Dave Attached image(s) ![]() |
Lo-Fi Version | Time is now: 9th July 2025 - 03:08 PM |
