Hyfire and silver dot tach - Working!, Mod your tach to work with a hyfire box |
agrump |
Apr 10 2005, 05:31 AM
Member Group: Members Posts: 141 Joined: 13-November 04 From: Atlanta, GA Member No.: 3,103 |
My early silver dot tach did not work at all once I installed a hyfire ignition box. This is caused by the fact that the stock tack is looking for a high voltage signal that no longer exist. I was able to modify the tach to run off of the Hyfire's tach port by placing a jumper over the initial signal resister. As a side note I experimented with the hyfire's tach testor and found that the stock tach is pretty acurate.
Attached image(s) |
machina |
Apr 11 2005, 05:46 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
hey dean,
you seem to know your way around a circuit board. How hard do you think it would be to transplant the guts of my autometer into the silver dot porsche tach? I wouldn't want to do it if I couldn't use the silver dot needle. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:37 PM |
