meursault |
Idjit Savant ![]() ![]() Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 ![]() |
I occasionally help out with this 914 racecar that's putting out 400+ horsepower, normally aspirated. Either the motor or the driver has found a way to blow apart just about everything involved with putting that power to the wheels. Recently the car has been having clutch problems. Factory race clutch packages which supposedly handle 500 horsepower aren't cutting it.
The car was at Fontana this weekend. I was about to go up to join the race crew when I learned that the car broke...again...so I stayed behind and helped when the car came back. Here's what awaited us as we began to investigate. Hmm, clutch is stuck in a state of engagement. Spline area of the clutch disk sits askew. And what's that copper stuff trying to poke out of the clutch package at the lower left? Attached image(s) ![]() |
meursault |
QUOTE His output shafts are stock early 911. There is really nothing special about them. The sporto did use them.. but so did all the early 901/911 boxes. Actually, no. The only gearboxes in which I have found that particular length flange is the sportomatic. Believe me, I have a large selection of transmissions to look at. For example, the gearbox I converted for use in a 914 was complete and had flanges with the right bolt pattern. They were just a bit too short, though. I assembled a stock 914 axle from stub axle to flange and a 911 axle with the large CVs from stub axle to flange. Only the sportomatic flange and the 72-73 shaft made up the distance to give me an equal length axle. |
Lo-Fi Version | Time is now: 3rd July 2025 - 11:07 PM |
