beemie96 |
Member ![]() ![]() Group: Members Posts: 98 Joined: 15-July 04 From: Nashville, TN Member No.: 2,350 ![]() |
Okay, got the fuel pump pumping gas to the rail... (thanks to all that piped in there). (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Now, I don't know if I'm getting spark. Basically, what is the checklist for a non-starting car? the basic stuff first, since I think the car ran a number of years ago, and it's still looks pretty un-messed with, BUT, it looks like the coil is new, and some wiring and vaccuum hosing is new / cleaned. So, I'm going to check the wiring to the coil and the sensors, make sure they're clean and un-broken and wired properly... i'd have done it last night, but it was midnight when i got the fuel pump going. otherwise, though, what's the easiest way to verify that the plug are getting spark? without pulling the plugs... don't want to do that if I don't have to, i've stripped those things before... and that makes for a bad day. |
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Get a spark plug and stick it on one of the plug wires. Ground the threads of the plug to the engine case. get someone to crank the engine over. should be nice strong blue spark. If you got a hot coil or CDI box keep your fingers clear cause THAT SPARK will hurt like hell.
Lo-Fi Version | Time is now: 4th July 2025 - 12:13 AM |
