beemie96 |
Member ![]() ![]() Group: Members Posts: 98 Joined: 15-July 04 From: Nashville, TN Member No.: 2,350 ![]() |
Okay, got the fuel pump pumping gas to the rail... (thanks to all that piped in there). (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Now, I don't know if I'm getting spark. Basically, what is the checklist for a non-starting car? the basic stuff first, since I think the car ran a number of years ago, and it's still looks pretty un-messed with, BUT, it looks like the coil is new, and some wiring and vaccuum hosing is new / cleaned. So, I'm going to check the wiring to the coil and the sensors, make sure they're clean and un-broken and wired properly... i'd have done it last night, but it was midnight when i got the fuel pump going. otherwise, though, what's the easiest way to verify that the plug are getting spark? without pulling the plugs... don't want to do that if I don't have to, i've stripped those things before... and that makes for a bad day. |
Porsche Rescue |
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None ![]() |
If you have a timing light you can do it without assistance. Hook up the light to #1 wire. Should be enough line so you can stand at driver's door and turn engine over while holding trigger on the light. If it flashes you have spark. Test the other 3 as well if you feel the need.
Lo-Fi Version | Time is now: 4th July 2025 - 12:21 AM |
