Help emissions failure, bah! fail HC at idle |
TravisNeff |
Apr 14 2005, 01:35 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Well, I tuned up the 914 (72 1.7) and drove the hell out of it before my emissions test. It failed HC at idle, here's the results:
HC Loaded Reading: 123 PASS Loaded Standard: 400 Idle Reading: 431 FAIL Idle Standard: 400 CO Loaded Reading: 0.27 PASS Loaded Standard: 4.2 Idle Reading: 0.30 PASS Idle Standard: 5.50 I set the ECU all the way counter clockwise and adjusted my idle to around 1100 for the test. Maybe I set this the wrong way? I set it per Brad Anders' webpage suggests. Or maybe TPS? Since I passed so well on the others, I don't want to undo what I did right for my idle test. Could be a vacuum leak I have a 200-300 rpm hunt - hoses check out so I am left with plenum gaskets, cold start gaskets or a cracked plenum. Gimme some ideas! |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:50 AM |
