l-jet gurus need input, l-jet lean running |
ablose58 |
Apr 14 2005, 11:55 PM
rust never sleeps Group: Members Posts: 584 Joined: 6-December 03 From: port orchard,wa. Member No.: 1,422 |
Thanks in advance for the advice, I have a 74 1.8 l-jet and I just replaced vac hoses intake boots and gaskets/fuel inj seals etc. I also installed an air/fuel mix gauge and the gauge indicates that I am running quite lean also my cyl head temp seems a little high too,around 350f so what's the best way to richen my overall mixture so head temps and air /fuel mix is closer to 14.7 or stoich if you will ? thanks again AL (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif)
MartyYeoman |
Apr 15 2005, 10:10 AM
Senior Member Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Try adding a 300 to 500 Ohm resister between the head temperture sensor and the wireing harness.
A 280 Ohm adds about 1% CO. |
Lo-Fi Version | Time is now: 10th June 2024 - 03:04 AM |
