Help emissions failure, bah! fail HC at idle |
TravisNeff |
Apr 14 2005, 01:35 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Well, I tuned up the 914 (72 1.7) and drove the hell out of it before my emissions test. It failed HC at idle, here's the results:
HC Loaded Reading: 123 PASS Loaded Standard: 400 Idle Reading: 431 FAIL Idle Standard: 400 CO Loaded Reading: 0.27 PASS Loaded Standard: 4.2 Idle Reading: 0.30 PASS Idle Standard: 5.50 I set the ECU all the way counter clockwise and adjusted my idle to around 1100 for the test. Maybe I set this the wrong way? I set it per Brad Anders' webpage suggests. Or maybe TPS? Since I passed so well on the others, I don't want to undo what I did right for my idle test. Could be a vacuum leak I have a 200-300 rpm hunt - hoses check out so I am left with plenum gaskets, cold start gaskets or a cracked plenum. Gimme some ideas! |
TravisNeff |
Apr 15 2005, 10:29 AM
Thanks Jason.
I sat in the passenger seat and had to help them get it into first gear each time, of course they pulled it back out of gear and put it in 3rd. I giggled when they put the fan in front of the car to cool the radiator. If I get the option to get tags for 2 years and skip next years test - I'm all over that.. |
Lo-Fi Version | Time is now: 10th June 2024 - 10:20 AM |
