> 914 V8 Guys or SBC gurus, Need help on a 283 SBC build
nine14cats
post Apr 15 2005, 06:57 PM
Bill Pickering -- 914-6 GT aka....Leeloo
Hi folks,
Working on my 914 V8 dreams...made an offer on a car that will give me the vehicle, have the kit selected, now onto the motor.
I have spoken with several shops concerning the 350 V8. Lots of options to choose from. I also have access to a fellow 914Club members 283 V8. I like the thought of a 3 inch stroke motor.
When calling around local machine shops (SF Bay Area) not as many 283 gurus as I would have thought. The older guys are dead and the younger guys only know 350's.
I would like opinions of what components to use on my motor if I go 283. I want:
1. Reliability
2. A quick rev machine
3. Off the shelf components (as in manifolds, heads, carbs.)
The car will be carbed. Alum heads. I have headers. HEI disty.
It will run a Renegade or Desert Hybrids kit. It will have heat and A/C.
The purpose of this car will be:
1. California Cruisin
2. No Track time
3. No Autocross
For tranny it will run a tall gear 901 fully rebuilt.
I am looking for at least 283HP (1 HP per cube) but torque no greater than 300 ft/lbs to make the tranny last as long as possible.
A revver would be fine with Alumininum heads, roller rockers or cams. I am intriqued by the Rod Simpson camshalfts that use the Miller high static compression ratio.
But I want you folks to chime in with recommended combos including part numbers if possible.
And any good machine shops in the SF bay area that specialize in hot rod SBC's would be greatly appreciated.
Thanks for your help!
Bill P.
86motoman
post Apr 15 2005, 09:57 PM
Here: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...ssPageName=WDVW
If you decide to go this route, these guys will help with the engine management: www.ls1.com and www.ls1tech.com. I think you will also need a wiring harness and pcm and other crap. The trick is to get a computer that hasn't been reprogrammed or if it has set back to stock settings before shipped.
nine14cats   914 V8 Guys or SBC gurus   Apr 15 2005, 06:57 PM
Headrage   Scott Kline would be a good one to talk to. He ha...   Apr 15 2005, 07:02 PM
Mueller     Apr 15 2005, 07:09 PM
neo914-6   Not sure if he does 283's but Renegade uses Wi...   Apr 15 2005, 08:24 PM
Brad Roberts
  Apr 15 2005, 08:35 PM
trekkor   Bill, you can pick up a good used Corvette 350 at ...   Apr 15 2005, 08:42 PM
Brad Roberts   We can build a 454CI small block for 15k..LOL Bil...   Apr 15 2005, 08:47 PM
Mueller   <...   Apr 15 2005, 08:47 PM
86motoman   Have you considered getting the "new" small block ...   Apr 15 2005, 09:45 PM
86motoman   Here: http://cgi.ebay.com/ebaymotors/ws/eBayISAP....   Apr 15 2005, 09:57 PM
neo914-6     Apr 16 2005, 08:49 AM
nine14cats   The comments about not much around anymore for a 2...   Apr 16 2005, 09:02 AM
skline   Well, I am going out to work on it now. I need to ...   Apr 16 2005, 09:15 AM
messix   thanx JP & Joe blown head gaskets? did they retorq...   Apr 16 2005, 12:54 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:36 PM
