Charging Issue, revisited...., not the Voltage regulator |
Aaron Cox |
Apr 16 2005, 12:03 PM
guys,
im having a heck of a time trying to figure out whats the problem. Gen light came on thursday night on my drive home. i measured voltage goin to the battery as follows: car off ~13 volts car idling 14 volts 1500 rpm 15.8 volts BAD i borrowed a new voltage regulator from bill 'grimstead' and it did not rectify the problem. all fuses are fine. all connections are solid. the belt is on nice and snug with the car off, the G light is lit car idling, it is lit, but very dim.... higher the rpm the less bright the bulb becomes.... now that i have eliminated the voltage reg as a failure mode... do i have a crapped out alternator? where is the best place to buy a new alternator? help me before the WCC... i dont want to blow up my optima.... |
bondo |
Apr 16 2005, 12:38 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
The AC is generated at the outside windings. The brushes are for the field, which is DC energized and controlled by the regulator. The more that goes to the field, the more that comes out on the AC side. I don't see how bad brushes could make it overcharge. It could be a bad battery, or it could be a bad diode that's confusing your meter. Got an oscilloscope? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 07:16 AM |
