Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,542 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California ![]() |
guys,
im having a heck of a time trying to figure out whats the problem. Gen light came on thursday night on my drive home. i measured voltage goin to the battery as follows: car off ~13 volts car idling 14 volts 1500 rpm 15.8 volts BAD i borrowed a new voltage regulator from bill 'grimstead' and it did not rectify the problem. all fuses are fine. all connections are solid. the belt is on nice and snug with the car off, the G light is lit car idling, it is lit, but very dim.... higher the rpm the less bright the bulb becomes.... now that i have eliminated the voltage reg as a failure mode... do i have a crapped out alternator? where is the best place to buy a new alternator? help me before the WCC... i dont want to blow up my optima.... |
brp914 |
Unregistered ![]() |
imho alternators dont go bad by generating excess voltage. I have had the alt light come on due to shorts on the same cicuit that it is on. In my case it turned out to be the engine compartment light. The wire to it had been spliced at some point in the past. Well it unspliced and was dangling down and shorting against the body. For some reason the alt light was especially bright when braking. I've heard where the reverse light wire doing the same thing. Better do a little troubleshooting with your vom and a schematic. IIRC this stuff goes to fuse 9. I wonder if pulling this fuse and looking to see if your alt light goes out would help locate the problem. good luck
Lo-Fi Version | Time is now: 1st July 2025 - 07:14 AM |
