Charging Issue, revisited...., not the Voltage regulator |
Aaron Cox |
Apr 16 2005, 12:03 PM
guys,
im having a heck of a time trying to figure out whats the problem. Gen light came on thursday night on my drive home. i measured voltage goin to the battery as follows: car off ~13 volts car idling 14 volts 1500 rpm 15.8 volts BAD i borrowed a new voltage regulator from bill 'grimstead' and it did not rectify the problem. all fuses are fine. all connections are solid. the belt is on nice and snug with the car off, the G light is lit car idling, it is lit, but very dim.... higher the rpm the less bright the bulb becomes.... now that i have eliminated the voltage reg as a failure mode... do i have a crapped out alternator? where is the best place to buy a new alternator? help me before the WCC... i dont want to blow up my optima.... |
bondo |
Apr 16 2005, 12:55 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
It takes alot of current to push an optima over 16v, unless its bad. It shouldn't be able to happen if everything is right. It could also be a short in the harness that's giving the full battery voltage 12v to the field. That COULD make the alt light come on, but I'm not sure. Most FLAPS will test your charging system for free while its in the car. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:08 AM |
