Now it's my clutch... |
RustyWa |
Apr 13 2005, 11:44 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
My poor car is putting me to the test this week. I'm driving around today and start heading up this large hill in third gear, when it's obvious that my clutch is slipping. I've adjusted the cable out before and essentially if my foot even gets close to the clutch pedal, the clutch slips. In fact I have to be mindful of my shoe laces since the weight of them seems to cause slippage.
I'm going to look at it once more tomorrow, but I think I'll have to bite the bullet and pull the tranny. And to think I was getting all gung ho upgrade my control arm & trailing arm bushings. Looking at the Pelican site, they have a "Super Kit" for the low, low price of $387.75. Which includes the following: New Pressure Plate New 911 Clutch Disc New Throw-out Bearing New Pilot Bearing and Felt Ring 2 Throw-out Bearing Guide Clips New Throw-out Fork Bushing 2 CV Joint Gaskets 2 Muffler Gaskets New Flywheel O-Ring New Flywheel Bolts New Flywheel Metal Crush Gasket Clutch Disc Alignment Tool Flywheel/crankshaft seal not included - check yours first before ordering. Is this overkill? Anything else needed? |
sixnotfour |
Apr 16 2005, 04:33 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Looks like some one resurfaced the flywheel . There is an "A" distance from clutch surface to bolting surface ."B" clutch surface to presureplate mounting surface.
The Person machined the clutch surface only, allowing 1.Clutch to rub bolt heads, 2. Not enough clamping pressure.Distance to great. There is a spec I dont have it right now. Maybe it can be saved or buy new. |
Lo-Fi Version | Time is now: 8th June 2024 - 09:21 PM |
