Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
guys,
im having a heck of a time trying to figure out whats the problem. Gen light came on thursday night on my drive home. i measured voltage goin to the battery as follows: car off ~13 volts car idling 14 volts 1500 rpm 15.8 volts BAD i borrowed a new voltage regulator from bill 'grimstead' and it did not rectify the problem. all fuses are fine. all connections are solid. the belt is on nice and snug with the car off, the G light is lit car idling, it is lit, but very dim.... higher the rpm the less bright the bulb becomes.... now that i have eliminated the voltage reg as a failure mode... do i have a crapped out alternator? where is the best place to buy a new alternator? help me before the WCC... i dont want to blow up my optima.... |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Welby, I know how alternators work. I also understand basic electronics.
Your procedure is quite correct for testing an alternator that's not installed in the car, or is in the car but isn't hooked up to anything. However, when the car is running, no "variable resistor" is required. The battery has internal resistance. So do capacitors, for that matter. Any resistance is a load. From what I read, Aaron was not measuring the output of the alternator by disconnecting it from everything, he was measuring it with it in a running car, which meant the ignition and injection HAS to be getting power from the battery, so it presented a charging load to the alternator. Indeed, it presented the same charging load that is present most of the time when the car is running. If the voltage is higher than 15v under those conditions IT'S TOO HIGH. Buy a $30 voltmeter and hook it up to your battery terminals and drive around in the car. You'll find the voltage typically stays around 13-14v, assuming your car is operating properly. It never gets above 15v unless something is wrong. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:04 PM |
