Now it's my clutch... |
RustyWa |
Apr 13 2005, 11:44 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
My poor car is putting me to the test this week. I'm driving around today and start heading up this large hill in third gear, when it's obvious that my clutch is slipping. I've adjusted the cable out before and essentially if my foot even gets close to the clutch pedal, the clutch slips. In fact I have to be mindful of my shoe laces since the weight of them seems to cause slippage.
I'm going to look at it once more tomorrow, but I think I'll have to bite the bullet and pull the tranny. And to think I was getting all gung ho upgrade my control arm & trailing arm bushings. Looking at the Pelican site, they have a "Super Kit" for the low, low price of $387.75. Which includes the following: New Pressure Plate New 911 Clutch Disc New Throw-out Bearing New Pilot Bearing and Felt Ring 2 Throw-out Bearing Guide Clips New Throw-out Fork Bushing 2 CV Joint Gaskets 2 Muffler Gaskets New Flywheel O-Ring New Flywheel Bolts New Flywheel Metal Crush Gasket Clutch Disc Alignment Tool Flywheel/crankshaft seal not included - check yours first before ordering. Is this overkill? Anything else needed? |
RustyWa |
Apr 16 2005, 07:47 PM
The "A"s stamped on the flywheel and visable in my photo, are those stamped when a resurface is done?
How do you guys know it was resurfaced and only on the "A" side? Will I have problems with the flywheel bolts? Do they need to be machined down? I guess this all depends on if the shop tells me the flywheel is usable. If it is not usable, what would happen if I just scuffed up the surface and reused? The engine has at least 95k on it and surely would be the weak link. Thanks |
Lo-Fi Version | Time is now: 8th June 2024 - 04:31 PM |
