Blue smoke on decel, Part 2, Compression and vacuum test results |
DNHunt |
Jun 24 2003, 10:21 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Engine at normal operating temperature
Compression #1 #2 #3 #4 110 100 100 100 Compression after 3cc's of 30 wt oil added to each cylinder #1 #2 #3 #4 110 102 110 110 Vacuum was steady at 16 in hg. Relatively new plugs look a little foul. It looks like all cylinders could be higher. However, this is a brand new compression gauge so I have no readings taken previously and I have no way to know if it reads high or low. From what's been explained to me it appears that 3 & 4 have some ring problems because the addition of oil improved the compression. I also suspect some valve guide problems but it wouldn't hurt my feelings if you guys told me I was way off base. So, wade in and tell me what you think. Dave |
Slowpoke |
Jun 24 2003, 10:51 PM
Member Group: Members Posts: 116 Joined: 1-June 03 From: Tucson, AZ Member No.: 768 |
Compression test are over rated. Do a leak down test. If you don't have the gauges to do that. Bring each piston up in the cylinder on a compression stroke and braze up an old spark plug and a chuck for you compressor's air line. Then put the car in 5th and have some one apply the brakes and put about 80 psi into the cylinder and listen for where you hear the air leaking out. Oil cap or exhaust or carb you should hear some, but if it sounds like alot ahhhhh...bad news. Then you'll know where the problem is with that cylinder.
I think you have a valve guide/seal issue. I'm not a air cooled experience person. But, that would be my guess. Good luck |
Lo-Fi Version | Time is now: 12th June 2024 - 01:33 AM |
