My car tried to kill me!, Smelly clutch, and now no breaks? |
D-Jet |
Apr 21 2005, 10:53 PM
Newbie Group: Members Posts: 37 Joined: 26-February 05 From: LA, CA Member No.: 3,668 |
Sunday I started smelling my clutch. A nasty smell if there ever was one. What was confusing was that it didn’t feel like it was slipping at all. Just the smell. So I drove it briefly on Tuesday and it seemed fine. I drove it a little further tonight and it started smelling again. It was about this point I noticed I had NO BREAKS. A fun experience. If you ever get a chance, pass. I pumped the pedal a few times and they came back. I headed home immediately. The smell on the clutch kept getting worse, and it became harder and harder to get in gear. Every time I tried to stop, I had to pump the breaks about 4 times and then I’d get pretty much regular pedal feel and stopping power. I’m so confused.
The car recently had its breaks bled. The breaks were fine before I started smelling the clutch. At least, I think it’s the clutch. Is there something that smells like clutch that it could be? Occasionally, the gas pedal feels like there is something preventing it from going down. If I push it a little harder, past the resistance, it’s fine. The resistance varies and isn’t always in the same spot (I don’t think). Not sure if this is related, but I figured it was worth mentioning. Even as I approached home, the clutch didn’t feel like it was slipping, though it was very hard to get into any gear. First gear made an even worse racket than it usually does. Any ideas? --G (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
mightyohm |
Apr 21 2005, 11:06 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Is your parking brake stuck on? That will smell bad and cause your brakes to fail sooner or later when the fluid boils.
Is your transmission filled with fluid? Is your clutch adjusted correctly? How is the clutch tube in the center tunnel? |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:25 AM |
