My car tried to kill me!, Smelly clutch, and now no breaks? |
D-Jet |
Apr 21 2005, 10:53 PM
Newbie Group: Members Posts: 37 Joined: 26-February 05 From: LA, CA Member No.: 3,668 |
Sunday I started smelling my clutch. A nasty smell if there ever was one. What was confusing was that it didn’t feel like it was slipping at all. Just the smell. So I drove it briefly on Tuesday and it seemed fine. I drove it a little further tonight and it started smelling again. It was about this point I noticed I had NO BREAKS. A fun experience. If you ever get a chance, pass. I pumped the pedal a few times and they came back. I headed home immediately. The smell on the clutch kept getting worse, and it became harder and harder to get in gear. Every time I tried to stop, I had to pump the breaks about 4 times and then I’d get pretty much regular pedal feel and stopping power. I’m so confused.
The car recently had its breaks bled. The breaks were fine before I started smelling the clutch. At least, I think it’s the clutch. Is there something that smells like clutch that it could be? Occasionally, the gas pedal feels like there is something preventing it from going down. If I push it a little harder, past the resistance, it’s fine. The resistance varies and isn’t always in the same spot (I don’t think). Not sure if this is related, but I figured it was worth mentioning. Even as I approached home, the clutch didn’t feel like it was slipping, though it was very hard to get into any gear. First gear made an even worse racket than it usually does. Any ideas? --G (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
SGB |
Apr 22 2005, 08:49 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I think you also have deteriorating bushings in the shift linkage. There is one at the firewall that is like a U-joint and takes a lot of loading when you force shifts, like you may have done when brakes were dragging....
Mine was fine untill I replaced bushings at the back of the linkage, then the added resistance or inflexibility caused the front bushing to go from "loose" to "gone" in a couple of days. It was more noticable on side to side lever movement- in fact the 2-3 slot was just gone most of the time.... shift improvements |
Lo-Fi Version | Time is now: 10th June 2024 - 08:34 PM |
