John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
This past weekend, I did my first track event of the year (have been doing them for the last 18 years).
I started hearing a clunking noise from the rear. It sounded like it was coming from the Left Rear (Driver side). I checked it out and the only thing I could find was that if you grab the axle shaft and vigerously shake it side to side, the axle shaft will bottom out and cause the clunking sound I am hearing out on the track. What I believe has happened is that there is no grease left at the end between the stub shaft and the end of the axle to cusion the shaft movement. Here is part of my problem. I bought the axle shafts from Patrick Motorsports 2-3 years ago when I did the 915/916 transmission, and they are different axle shafts. The stub shaft is connected to the CV joint and the other CV joint (tranny end) has a sealing cap crimped to it. I don't know if it is perminantly attached, or if it comes off. Are the axle shafts worn out when you can move the axle shaft like this, or do they need grease. If they need grease, how do I get the grease in where I think they need it? The only changes I made to the rear suspension this winter was to lower it about 3/4" (axle shafts are horizontal), increase the spring rate from 350# to 400#, and align it. I have checked everything out and nothing is loose. Any ideas, suggestions, or wisecracks welcomed. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
The axles shouldn't hit the stub axle.
What axles are they? My guess is they are too long. By lowering your car you are now in essence seeing the full length of the axle in their new horizontal stance and it is hitting the stub axle. No amount of grease will stop it. You may be able to remove some material from the inside of your stub axle but it sounds like the axle length is wrong. You'll also wear out your CV's much faster than normal. I recall this being a problem with 911 axles in 914 applications... don't know for sure. Just a shot in the dark. |
Lo-Fi Version | Time is now: 11th July 2025 - 03:55 AM |
