> EE help, Voltage Drop over copper
bd1308
post May 2 2005, 10:08 PM
Sir Post-a-lot
okay, i have a question. I'm trying to do Power-Over-Ethernet using the (unused) blue pair of ethernet wires. 5VDC......i run the wire (~70 or so feet) and plug it in, and not enough voltage to boot my wireless router....seems that i need under 1.4VDC....how the hell can i add 5VDC to 1.4VDC. I tried getting one of those adjustable AC adaptors and hooking them in series and parallel... in series neither worked...got like 1VDC, and in parallel, well....i tested it later (after it was working) and found the voltage to be around 14-15VDC.....what the hell?
AC adaptor->modified 10/100->~70 foot run to attic->blue pair seperated from RJ45 Jack->in-to router.
bondo
post May 2 2005, 11:20 PM
What you need is a power supply with remote sensing.. two wires will power your device.. two other wires will carry no current but measure the voltage at the device. The power supply will use the voltage at the device to regulate its ouput. Thus if you need 9v to get 5v, it will do that. Unfotunately such a supply will cost more, and you'll need 4 wires.
Just do what jkeyzer and lapuwali said. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
bd1308   EE help   May 2 2005, 10:08 PM
914GT   First of all, your adapter needs to be able to sup...   May 2 2005, 10:19 PM
jkeyzer   Ohms law will tell you the voltage drop to expect ...   May 2 2005, 10:20 PM
lapuwali   I was just about to type in almost exactly what jk...   May 2 2005, 10:30 PM
Loser_Cruiser   If you truly need a power over CAT 5 cable, it wou...   May 2 2005, 10:47 PM
bondo   What you need is a power supply with remote sensin...   May 2 2005, 11:20 PM
bd1308   the AC adaptor is OEM.....5VDC....regulator would ...   May 2 2005, 11:33 PM
bd1308   ethernet does have 2 unused pairs....cool stuff. h...   May 2 2005, 11:36 PM
bondo     May 2 2005, 11:44 PM
bd1308   okay....just thought of something....why couldn...   May 2 2005, 11:52 PM
lapuwali     May 3 2005, 09:09 AM
jkeyzer   Make sure the 9V adapter is capable of supplying t...   May 3 2005, 09:19 AM
Dr. Roger   won't the EMF surrounding these power wires to...   May 3 2005, 09:36 AM
jkeyzer   Well regulated DC will not have a significant effe...   May 3 2005, 10:12 AM
davep   DC can cause problems also if the current draw is ...   May 3 2005, 10:21 AM
Tom Perso   Couldn't you just double up the wires? Ethern...   May 3 2005, 10:29 AM
bd1308   jkeyzer: AC power wouldnt work...the bleedthrough ...   May 3 2005, 10:42 AM
bondo   ...   May 3 2005, 05:26 PM
bd1308   yeah...i'm just not so sure about this whole b...   May 3 2005, 06:34 PM
914GT   Lynksys makes a power over ethernet adapter kit. I...   May 3 2005, 07:45 PM
bondo     May 3 2005, 07:51 PM
- Lo-Fi Version Time is now: 4th July 2025 - 10:51 AM
