bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
okay, i have a question. I'm trying to do Power-Over-Ethernet using the (unused) blue pair of ethernet wires. 5VDC......i run the wire (~70 or so feet) and plug it in, and not enough voltage to boot my wireless router....seems that i need under 1.4VDC....how the hell can i add 5VDC to 1.4VDC. I tried getting one of those adjustable AC adaptors and hooking them in series and parallel... in series neither worked...got like 1VDC, and in parallel, well....i tested it later (after it was working) and found the voltage to be around 14-15VDC.....what the hell?
AC adaptor->modified 10/100->~70 foot run to attic->blue pair seperated from RJ45 Jack->in-to router. |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Again, the router very probably has a 5V voltage regulator inside. No need to regulate at the router, as long as you don't give it way too much voltage. A 9V wall wart with a 3V drop across your cable is 6V at the router, which an onboard 5V regulator will handle just fine. |
Lo-Fi Version | Time is now: 4th July 2025 - 11:42 AM |
