> Bleeding Bleeding Bleeding AIR???, give me a quick hand ...
RangerRhett
post May 4 2005, 09:13 PM
I started to bleed the brakes tonight.
I know the order:
Right Rear
Left Rear
Right Front
Left Front
Even when I started, I was getting bubbles in my hand pump (with cannister) . Now I get no, zero resitance on the brake Pedal. None...Zero...
Should I close up all the nipples, push on the pedal a few times and then start over....repeat, repeat, repeat until I get a steady stream of brake fluid...?
'Lil Help on this one..
SLITS
post May 4 2005, 09:16 PM
"This Utah shit is HARSH!"
Did the MC run dry at any time?
Crack the connections at the MC, bleed it and start over again.
Best guess............
RangerRhett   Bleeding Bleeding Bleeding AIR???   May 4 2005, 09:13 PM
SLITS   Did the MC run dry at any time? Crack the connect...   May 4 2005, 09:16 PM
914fire   As long as you have air in your lines your going t...   May 4 2005, 09:17 PM
xsboost90   did mine the other nite. filled resevoir, closed b...   May 4 2005, 09:18 PM
RangerRhett   The Reservoir was always full...When I would take ...   May 4 2005, 09:19 PM
bondo   Those mityvac brake bleeders work in a pinch but t...   May 4 2005, 09:20 PM
Andyrew   You opened up all the valves at the same time? Wha...   May 4 2005, 09:21 PM
SLITS   Just crack the connections at the MC and let it gr...   May 4 2005, 09:23 PM
RangerRhett   There is no way the MC is bad...it was working gre...   May 4 2005, 09:26 PM
Dave Blackburn   I have a vacuume bleeder and have had a few proble...   May 4 2005, 09:26 PM
RangerRhett   Guys, How do I get the fluid back through the bra...   May 4 2005, 09:33 PM
914fire   pump pump pump.....   May 4 2005, 09:35 PM
RangerRhett     May 4 2005, 09:35 PM
Thorshammer   Slits is right, crack the master cylinder and let ...   May 4 2005, 09:51 PM
trekkor   Good thread. I'll be doing this shortly mysel...   May 4 2005, 10:08 PM
sgomes   I know every time we have one of these brake bleed...   May 4 2005, 10:27 PM
914GT   Here are a couple of tips for good brake bleeding ...   May 4 2005, 10:30 PM
!   S P E E D B L E E D E R S   May 4 2005, 10:38 PM
914GT
- Lo-Fi Version Time is now: 4th July 2025 - 03:52 PM
