RangerRhett |
Member ![]() ![]() Group: Members Posts: 131 Joined: 25-August 04 From: Lafayette, IN Member No.: 2,620 ![]() |
I started to bleed the brakes tonight.
I know the order: Right Rear Left Rear Right Front Left Front Even when I started, I was getting bubbles in my hand pump (with cannister) . Now I get no, zero resitance on the brake Pedal. None...Zero... Should I close up all the nipples, push on the pedal a few times and then start over....repeat, repeat, repeat until I get a steady stream of brake fluid...? 'Lil Help on this one.. |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
You opened up all the valves at the same time? What kind of bleed system you using?
Speed bleeders? You need to only have one valve open unless your running speed bleeders. Andrew |
Lo-Fi Version | Time is now: 4th July 2025 - 12:44 PM |
