RangerRhett |
Member ![]() ![]() Group: Members Posts: 131 Joined: 25-August 04 From: Lafayette, IN Member No.: 2,620 ![]() |
I started to bleed the brakes tonight.
I know the order: Right Rear Left Rear Right Front Left Front Even when I started, I was getting bubbles in my hand pump (with cannister) . Now I get no, zero resitance on the brake Pedal. None...Zero... Should I close up all the nipples, push on the pedal a few times and then start over....repeat, repeat, repeat until I get a steady stream of brake fluid...? 'Lil Help on this one.. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Just crack the connections at the MC and let it gravity bleed.....drip, drip, drip, then tighten them. If the thingy was full all the time, you may have sucked a shit pile of air into the lines and the MC is ok.
And if all the bleeders were open at the same time, you sucked a bunch of air thru three while you were working on one. |
Lo-Fi Version | Time is now: 4th July 2025 - 12:53 PM |
