Fan housing blockoff, no heat |
MattR |
May 9 2005, 01:08 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
From what I understand of the 914 heating system, the fan housing outlets have to be blocked off if I'm not running heat. Can anyone give suggestions on how to block these off? I could weld them up, but Im not sure about the material, and I'd like to be able to seperate the fan housing without grinding and rewelding.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1110132454.jpg) (those outlets at the bottom) |
MattR |
May 9 2005, 03:01 PM
Not as much flaps, but outlets. These outlets go to the flapper boxes connected to the heat exchanger, which are controlled by the driver (on the tunnel). Opening the flapper boxes lets moving air into the hot heat exchangers and into the longs to toast your feet and to the blower assembly next to the gas tank to defrost the window.
Lo-Fi Version | Time is now: 4th June 2024 - 07:05 PM |
