> It finally happened, Starter question
jimtab
post May 4 2005, 09:49 PM
On the way back from the wcc after 5 straight hours on the 5 I stopped for a late dinner in Gilroy, when I came back out the biach wouldn't start, plenty of juice but no crank. I got it push started with some local help. When I got home I restarted twice so I thought...hot start problem....but no.....when I tried to start it yesterday am it was the same as in Gilroy, juice but no crank. Sooooo, where do I start to look, the starter, loose wires, which wires? I guess the car just found out I'm gonna get the body and paint done and couldn't stand ti anymore.....three years down the drain....spoiled a perfect record. Help! Thanks, Jim
Rand
post May 9 2005, 04:08 PM
Cross Member
do I need to have the key on while doing this?
No. The large cable goes straight to the battery. It's always hot. The ignition doesn't need to be on because you aren't trying to start the car this way, only to see if it tries to crank. One quick tap and release between the main power and the solenoid will tell you. If it tries, you'll be pulling back instantly and know that your starter, solenoid, power, ground, etc. are all likely good. If it's dead, then check for 12v.
A more comfortable way to test this is to make a couple heavy gauge test leads... alligator clips on each end, a push button switch in the middle. Then you can hook one alligator clip to the power terminal, another to the solenoid wire (big yellow wire - if not on solenoid, then at the relay). Hit the push button and see if it tries to crank.
Anyway, sounds like you're replacing parts. Please let us know what the fix was.
jimtab   It finally happened   May 4 2005, 09:49 PM
bd1308   sounds like a bad starter (EDIT) Solonoid.....it t...   May 4 2005, 09:51 PM
914GT   So you've ruled out the hot starter solenoid p...   May 4 2005, 10:38 PM
Bruce Allert   Replaced my original starter with a '68 911 s...   May 4 2005, 11:38 PM
Rand   There are quite a few threads on this. As for me, ...   May 5 2005, 12:52 PM
Cap'n Krusty   http://www.914world.com/bbs2/ht...   May 8 2005, 05:59 AM
markb   Jim? Were you going to post a pic so we know what ...   May 8 2005, 06:08 AM
jimtab   I'm trying to resize the photo so it will load...   May 8 2005, 06:20 AM
jimtab   one more   May 8 2005, 06:22 AM
markb   Looks like you've got the "ford soleniod hot s...   May 8 2005, 06:26 AM
xsboost90   first day i bought my car it had this, it had a bu...   May 8 2005, 08:20 AM
!   Looks like yer band aid has done it's job........   May 8 2005, 08:38 AM
Rand   The previous owner had installed a hot start relay...   May 8 2005, 01:04 PM
MattR   The PO installed one of those in my 912 and it had...   May 8 2005, 01:16 PM
jimtab   Thanks to everyone, I got it out and called my FLA...   May 8 2005, 02:56 PM
John Kelly   Sometimes if you whack the starter with a wrench i...   May 8 2005, 03:52 PM
sean_v8_914   I just sold my yellow 72 914 to Ben. he posts here...   May 8 2005, 04:29 PM
ben1440   It seems like a hot start issue. it happened at 2...   May 9 2005, 08:16 AM
Steve Thacker   I also had the hot start issue, even with all new ...   May 9 2005, 09:35 AM
Rand     May 9 2005, 04:08 PMDr. Roger   BIG emphasis on making sure it's out of gear.....   May 9 2005, 04:30 PM
jimtab   It's all better, I got the new starter and it ...   May 9 2005, 10:56 PM
AZ914   Jim, This same thing happened to me over the week...   May 10 2005, 10:38 AM
Dr. Roger   I hope this isn't a dumb question but do you h...   May 10 2005, 11:21 AM
- Lo-Fi Version Time is now: 11th July 2025 - 12:10 PM
