Fan housing blockoff, no heat |
MattR |
May 9 2005, 01:08 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
From what I understand of the 914 heating system, the fan housing outlets have to be blocked off if I'm not running heat. Can anyone give suggestions on how to block these off? I could weld them up, but Im not sure about the material, and I'd like to be able to seperate the fan housing without grinding and rewelding.
(IMG:http://www.914world.com/bbs2/uploads/post-2-1110132454.jpg) (those outlets at the bottom) |
SirAndy |
May 9 2005, 05:06 PM
Resident German Group: Admin Posts: 41,662 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) those outlets don't drive the *real* heat in a 914 anyways. that is done by the external blower in the engine comp. the one you start up when you move that red lever on the center tunnel. as soon as you do that, the pressurized air from that fan will close the little flappers on the housing outlets. this is done to avoid the big cooling fan sucking in hot air from the heat exchangers. i'd say, expoxy it close and be done with it ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Lo-Fi Version | Time is now: 29th May 2024 - 05:02 AM |
