Shaved doors, Shaved doors |
Howie's 914 |
May 10 2005, 08:27 PM
Member Group: Members Posts: 76 Joined: 29-June 04 From: Greensboro, NC Member No.: 2,273 |
I was wondering if anyone out there has shaved the doors handles on their 914? I am in the middle of redoing my 71. I am going with fender flares and think shaved doors would finish it off with a clean look.
boxstr |
May 11 2005, 08:58 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Take a look at the new Cadillac sporty car, They left a space in the back so you can slide you hand in and pull the door open after it is unlocked.
**Door Opening System** The doors are opened by touching a pad located in openings at the rearward edges of each door. Once the pad is pressed, the doors unlock and open if the transmitter is within a 3'radius. To operate the ignition the driver presses a button on the instrument panel. The same button is pressed to stop the engine. As a safety feature the engine will not start unless the transmitter is in the car and the brake pedal is depressed. As well as eliminating the traditional problem of fumbling for keys, the Keyless Access system provides a high level of security. "It's hassle-free, simple and logical," said Leone. When leaving the car, the access system has a convenient auto-lock function. Attached image(s) |
Lo-Fi Version | Time is now: 31st May 2024 - 09:24 PM |
