Brake question, Soft pedal |
Mike's2nd914 |
Jul 4 2003, 04:52 PM
Member Group: Members Posts: 109 Joined: 26-April 03 From: Birmingham, AL Member No.: 616 |
Hey guys, I could use a little help. I just got finished bleeding down the brake system after rebuilding all four calipers. The brakes worked when I started this project but I had one (or more) calipers that were frozen. Now, the calipers all work great and I believe I have bled all the air out of the system but there is still way too much travel in the pedal and I have to pump the pedal a couple of times to get any brakeing. What's up? It took about a month and a half to get everything rebuilt during which time the car sat up with little or no fluid in the brake system. Could the master cylinder, that was working fine before this, could it have gone bad just sitting there? (IMG:style_emoticons/default/headbang.gif)
I appreciate any help or suggestions! |
nealnorlack |
Jul 4 2003, 07:17 PM
Unregistered |
Hi,
I had exactly the same situation with my 911. I rebuilt everything but the master cylinder. The problem is when there is no fluid around the seals in the master cylinder, the seals will dry up and shrink. It sounds like your system went without fluid in it for some time. Rebuild or replace the master cylinder, maybe with a 19mm one, bleed the system again using the tips in the previous messages and it should work great. Cheers, Elliot (IMG:style_emoticons/default/cool.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 04:42 PM |
