ammason |
Member ![]() ![]() Group: Members Posts: 88 Joined: 14-March 05 From: Sunny Honolulu Member No.: 3,758 Region Association: Hawaii ![]() |
On my way to work today my accel. cable decided to snap on the one place on the freeway with no shoulder. I tied the carb linkage to a casette-tape adapter to a shirt that I fed through my passenger window and yanked on that to give me gas to get the rest of the way to work. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Normally I'd just replace the cable, but this car has something wierd... a second little lever just in front of the center console that acts like a manual throttle - almost like a cruise control. I haven't opened it up yet to see what needs replacing (I've got to drive it home like this tonight), but I wanted to know if this was something you'd seen before. I originally bought the car from CAMP (running BEAUTIFULLY otherwise - still so glad I went there), and I think Craigh had said it was some kind of 914-6 cable that had been added... Do you guys have experience with this kind of cable? Is it a stock replacement part? What can I expect for the job? Any info appreciated... Thanks! Aaron |
ammason |
I guess my question, and I don't know if you'll even be able to answer this as it's a custom mod, is what kind of cable would I need to use?
The car is a 2.0L with carbs and the /6 hand throttle. It seems to be that the /6 cables ran back to the transmission and had a bracket there that connected with the carbs. My car does not have this - it's got dual webbers with the post-on-the-block style linkage (no hex rod - Craigh if you've still got the pics from CAMP, could you post?) that seems like it could use a standard throttle cable just fine. Were the /6 cables different at both ends? Did they connect at the pedal in the same way? If all I'm concerned about is getting a cable out of the cab, would I be able to use the /4 cable? Differences? Thanks! |
Lo-Fi Version | Time is now: 4th July 2025 - 08:27 PM |
