Master Cylinder Brace, Thanks for the idea Brant! |
TravisNeff |
May 12 2005, 10:40 PM
I braced up my MC today, Brant had some photos of a brace he made for his race car. I used the leftover brace from the AC condenser on the other car cut it to size and left a 90 degree corner. To that corner piece I welded a small strap - kind of like a T for more surface area to weld to the suspension cross member. Once in place I hose clamped it down then welded the brace to the cross member. Have to be careful and give yourself room to remove the MC later as well as room to put back in the splash pan.
Attached image(s) |
TravisNeff |
May 13 2005, 01:01 PM
Would there be any interest in purchasing braces? I would change the design a little and use 1/4 of a section of tube that matches the profile of the crosmember, have it an inch or so wide on either side of the brace so you could weld it in and hose clamp to the MC, or if you don't have a welder to hose clamp it to both the crossmember and the MC? Somewhere around $25??
I'd have to make a jig for bending the brace and another to weld the "T". If so, I will jack up the other car for mock up. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:15 PM |
