> Replacing rear trailing arm bushing., Is there any way to...
mike_the_man
post May 15 2005, 05:57 PM
I like stuff!
Is there any way to remove the trailing arms to replace the bushings without changing the alignment? Also, is there any way to tell if the bushings are bad without removing the trailing arms? I'm still trying to chase down a clunk coming from the rear of the car when ever I hit a bump, and I'm starting to wonder if the bushings might be shot. All advice is appreciated.
Thanks,
Eric_Shea
post May 15 2005, 06:53 PM
PMB Performance
You may want to take the 22mm nut off the inner mount and check the hole for an out of round condition. This would be the one on your suspension ear than comes down through the engine compartment. This shouldn't change the alignment and you can look at an area that would normally not be noticed (oblong mount under the nut).
CV Joints going can also be the culprit.
(Damn, I hope I got that right. I'm sure I'll hear about it if I didn't)
mike_the_man   Replacing rear trailing arm bushing.   May 15 2005, 05:57 PM
Lawrence   IMO, a clunk coming from the back end... hmmmm. 1...   May 15 2005, 06:04 PM
skline   It could be control arm bushings, one way to tell ...   May 15 2005, 06:36 PM
mike_the_man   Shocks are still good, as far as I can tell. I...   May 15 2005, 06:37 PM
Porsche Rescue   Regarding alignment, you could probably get it bac...   May 15 2005, 06:46 PM
Lawrence   I hate to ask the obvious... 1. Is the rear wind...   May 15 2005, 06:50 PM
Eric_Shea   You may want to take the 22mm nut off the inner mo...   May 15 2005, 06:53 PM
Lawrence
- Lo-Fi Version Time is now: 1st July 2025 - 01:55 PM
