Grattan National, Race Report |
groot |
May 16 2005, 11:03 AM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Bad weekend. My fault totally, too. I ran very well on Friday considering everything. I'm finally faster than my old race car (ITB Rabbit) in this car....when it's running well. I need to go up another step in 5th gear because I was maxed out on the straight (5400 RPM and no power). Based on my data, I'm getting ~110 horsepower and 130 lb/ft of torque (peak at 4500 RPM), which isn't too bad. I'm below 100 hp and 100 lb-ft at 5200 RPM.
So, the engine started to run poorly on Sat, and I figured it was the weather change. So, I changed jets and did the emergency practice on Sun before the race. Still sucked, but even worse. So, I pulled the plugs (which looked great) and reran all of the wires, hoping it was a loose connection. No dice. So, I figured I'd run the race to try and get some points. I made it 10 laps before it really went dead. Turns out it was my battery. It was fully charged on Friday. I use a booster box to reduce the load during starting, but it needs to be charged between sessions, I've learned. I'm running a huge Optima, too. So, I learned a lot, but no points. A couple others didn't finish and I dropped out of 3rd place. I was nowhere near the pace. I also learned that my steering rack mount is not strong enough, so I have to beef than up. The rack was moving when I turned in, creating quite a disturbing, disconnected feeling. I still have a mystery oil leak that I need to stop, too. I've stopped many of them, but there's a high pressure oil spray on the driver's side of the engine that I can't locate. It doesn't leak in the pits. Mid-Ohio in 2.5 weeks. |
groot |
May 16 2005, 11:09 AM
There were some good things, too.....
I've got some bugs worked out of my brakes. It's great feeling when you're still on full power as you drive right on by that last marker cone in the braking zone. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:55 AM |
