| solex |
May 16 2005, 09:27 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hello All,
I have recently replaced all of the flexible brake lines, pads and rotors. The MC seems to be realtively new and the calipers all function. After all of this work, I am still unimpressed with the brakes on this car. I have read the pelican article regarding the front caliper 320i upgrade. The article also suggest that the brakes in the 914-4 are not that good. No matter how hard I try I cannot lock up the fronts. Anyone who has done this upgrade care to comment? Does it make a significant difference? Thanks, Dan |
| Air_Cooled_Nut |
May 17 2005, 11:39 AM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
solex, this is gonna suck but maybe you should swap out the master cylinder. Also, compress each caliper and have an assistant press the brake pedal so you can WATCH the pistons move. What I would do is measure the thickness of the brake pad (but not the backing plate), compress the pistons all the way (at least flush with the caliper pad landing), then have the assistant s-l-o-w-l-y press the brake and continue to do so until the pistons moves the distance you measured on the pad. Move to the next caliper. You want to make SURE that the calipers are functioning correctly.
Watching each caliper work is more time consuming and it would seem that you're not getting pressure so I would try the master cylinder swap first. Could be a bad internal seal allowing fluid to squeeze past. BTW, when you go out and test the brakes, do you check the brake fluid resevoir afterwards? Is the fluid level the same? If it drops then you have a leak (obviously), possibly a ruptured line w/in the body. I know this is a failure point for the air-cooled VW cars...after years of no brake fluid cleaning the water rusts the brake lines from the inside out and one day a stomp on the brakes pops a line... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
solex Brakes, Brakes, Brakes May 16 2005, 09:27 AM
914GT I've got the 320i brakes and replaced the prop... May 16 2005, 09:51 AM
TROJANMAN i know there is debate on this issue, but i was to... May 16 2005, 09:55 AM
Cap'n Krusty And why, pray tell, would you want to lock up your... May 16 2005, 10:13 AM
davep http://www.914world.com/bbs2/h... May 16 2005, 10:23 AM
solex Cap'n
I was using the phrase "lock up" to co... May 16 2005, 10:25 AM
jwalters http://www.914world.com/bbs2/html/... May 16 2005, 10:26 AM
jwalters May 16 2005, 10:29 AM
solex J,
Thanks for the reply, I have bled the brakes m... May 16 2005, 10:30 AM
Brando May 16 2005, 10:32 AM
! I will add my $.02, if I may....you have a 30... May 16 2005, 10:34 AM
jwalters May 16 2005, 10:34 AM
Mueller May 16 2005, 10:35 AM
jwalters http://www.914world.com/bbs2/html/e... May 16 2005, 10:36 AM
jwalters Man, mine flexed like a cicus performer---but beca... May 16 2005, 10:38 AM
solex J, Mueller,
Tires are shit but have decent tread,... May 16 2005, 10:43 AM
jwalters http://www.914world.com/bbs2/htm... May 16 2005, 10:46 AM
Brando May 16 2005, 10:59 AM
davep ... May 16 2005, 11:57 AM
jwalters May 16 2005, 12:03 PM
Air_Cooled_Nut Okay, motorcycles, cars & trucks should ALL be abl... May 16 2005, 09:52 PM
trekkor
