Intake length vs torque, Just anthoer carb question No boobs |
Joe Ricard |
May 18 2005, 02:03 PM
So I have short intakes and 44IDF's with 38mm vents
How long of an intake should I go to with these carbs or should I go to 40 IDF's with 32 vents or 28 vents. I have some longer runner intakes and the other carbs so it's just a matter of experimenting I guess. 2.0L Bus piston Web 86B portmatch intake and exhaust ports. 13lb flywheel Bursch SSI Car weighs 1965 lbs 205/50-15 Kumho V700 R tires. Thought of playing with spacers under the carbs to get more length and maybe spacer under the common length velocity stack. Looking for more torque down lower to pull harder exiting the apex of tight AX turns. Whose got the experience of really been there done that? great gains or don't bother. |
SirAndy |
May 18 2005, 04:26 PM
Resident German Group: Admin Posts: 41,680 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
are we sure about this? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) because that's not what i have learned and that's also not what the factory had to say when i was researching the numbers on the various air-cooled porsche intake designs ... everything i dug up said that longer intake runners will promote low end torque. but i was only looking at porsche factory FI setups, maybe carbs operate differently? but then again, what do i know? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Andy |
Lo-Fi Version | Time is now: 10th June 2024 - 04:15 PM |
