> Intake length vs torque, Just anthoer carb question No boobs
Joe Ricard
post May 18 2005, 02:03 PM
CUMONIWANNARACEU
So I have short intakes and 44IDF's with 38mm vents
How long of an intake should I go to with these carbs or should I go to 40 IDF's with 32 vents or 28 vents.
I have some longer runner intakes and the other carbs so it's just a matter of experimenting I guess.
2.0L Bus piston Web 86B portmatch intake and exhaust ports. 13lb flywheel Bursch SSI Car weighs 1965 lbs 205/50-15 Kumho V700 R tires.
Thought of playing with spacers under the carbs to get more length and maybe spacer under the common length velocity stack. Looking for more torque down lower to pull harder exiting the apex of tight AX turns.
Whose got the experience of really been there done that? great gains or don't bother.
Joe Ricard
post May 18 2005, 07:43 PM
CUMONIWANNARACEU
Well I knew all that. But what I want is the recipe for the engine I have. I am going to try the 40 IDF long intake with 46mm opening at the top vs 50mm short intakes.
I may make up some spacer shims to lengthen the intake even more. Also try to lengthen the velocity stack. can't go to much as I have short filters.
I'll let you know how it goes.
By the way this motor does rock above 4500 RPM doesn't fall on it's nose ever I have seen 7200 RPM in 3rd. Co- driver thought I was going to scatter it all over the track.
That was 10,000 miles ago. I put a rev limiting rotor in it now. Shift light @ 5500 makes my shift About 6000.
Joe Ricard   Intake length vs torque   May 18 2005, 02:03 PM
Dr. Roger   Please correct me if i'm wrong anyone..... Ge...   May 18 2005, 03:25 PM
SirAndy   <...   May 18 2005, 04:18 PM
Aaron Cox   pull a move like mazda racing did- varying intake...   May 18 2005, 04:20 PM
SirAndy     May 18 2005, 04:26 PM
lapuwali   Andy's right. Long = low-end weighted power c...   May 18 2005, 04:40 PM
Dr. Roger   Well actually it's got way more than just inta...   May 18 2005, 05:00 PM
lapuwali   Nice theory. Wrong, but nice-sounding. You can t...   May 18 2005, 05:46 PM
jwalters   Yea, Andy is correct-- A good view of this in wor...   May 18 2005, 05:47 PM
Tom73   So why to make HP on a V8 do you use a "high rise"...   May 18 2005, 07:26 PM
Dr. Roger   That's right... http://www.91...   May 18 2005, 07:36 PM
Dr. Roger   OHHH CRAP! Why-oh-why will my hood not fit rig...   May 18 2005, 07:40 PM
Joe Ricard   Well I knew all that. But what I want is the recip...   May 18 2005, 07:43 PM
Joe Ricard     May 18 2005, 07:46 PM
SGB   Personal experience: really really short intake =...   May 18 2005, 07:49 PM
bondo   What I don't understand is why runner length w...   May 18 2005, 07:52 PM
scott thacher   i did get a ride in joe's car, with the except...   May 18 2005, 08:09 PM
Joe Ricard   Yea Scott, Your motor in my car and it would be pr...   May 18 2005, 08:15 PM
scott thacher   nope i have done almost nothing... got a new batte...   May 18 2005, 08:21 PM
messix   quick and dirty big and short= high rpm power ...   May 18 2005, 09:37 PM
Joe Ricard   OK Well I'm going to do it and then write down...   May 19 2005, 02:13 PM
JmuRiz   What was the thinking behind this type of setup......   May 20 2005, 08:32 AM
URY914     May 20 2005, 09:18 AM
kwales   Looks like organ pipes- each one tuned to a differ...   May 20 2005, 09:24 AM
don9146   Didn't Jake do a test of different length Webb...   May 20 2005, 09:30 AM
Dr. Roger   Excellent info. Quote: But there's also a per...   May 20 2005, 10:12 AM
Dr. Roger   Oh, on the Can Am thing... Those stacks were anot...   May 20 2005, 10:21 AM
bondo   So how DO you measure throttle response? That...   May 20 2005, 11:33 AM
JmuRiz   Great info on the ducati airbox design! The b...   May 20 2005, 11:44 AM
Dr. Roger   Hmmm, in my limited experiences with a few small b...   May 20 2005, 07:17 PM
Jake Raby   Due to the intake and exhaust port designs the TIV...   May 20 2005, 07:50 PM
lapuwali   Jake, I don't know where this "conventional w...   May 20 2005, 08:38 PM
J P Stein   From what I have read on the long stacks/short sta...   May 20 2005, 08:59 PM
Joe Ricard   Well the butt dyno tells me I have more torque low...   May 30 2005, 02:33 PM
Air_Cooled_Nut   ...   May 30 2005, 04:44 PM
messix   the stacks jake is using are doing nothing but smo...   May 30 2005, 10:18 PM
- Lo-Fi Version Time is now: 12th July 2025 - 03:55 PM
