Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
So I have short intakes and 44IDF's with 38mm vents
How long of an intake should I go to with these carbs or should I go to 40 IDF's with 32 vents or 28 vents. I have some longer runner intakes and the other carbs so it's just a matter of experimenting I guess. 2.0L Bus piston Web 86B portmatch intake and exhaust ports. 13lb flywheel Bursch SSI Car weighs 1965 lbs 205/50-15 Kumho V700 R tires. Thought of playing with spacers under the carbs to get more length and maybe spacer under the common length velocity stack. Looking for more torque down lower to pull harder exiting the apex of tight AX turns. Whose got the experience of really been there done that? great gains or don't bother. |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
What I don't understand is why runner length would affect anything at full throttle. With the butterfly all the way open, shouldn't it all be runner? Couldn't you get the best of both worlds by putting "runners" on the intake side of the throttle valve?
Hmm, I just realized... that's exactly what velocity stacks are for. Talk about reinventing the wheel! |
Lo-Fi Version | Time is now: 12th July 2025 - 03:38 PM |
