> Rebuilding CV's ... when is a CV considered bad?, I have one thats not like the others...
cha914
post May 18 2005, 09:08 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus
Ok, started hearing clunking on the driverside rear...figured its gotta be CV's (one of the few things I havn't touched yet on this car). I have a parts car that has sat for 15+ years, so I figure I will pull those axles "rebuild" them and throw them in my car (boots look new).
Spent last night doing the dirty deed (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) , and all went as well as can be expected, except for one joint. 3 of the joints look like they are orig, no markings except for a small vw stamp on them. One of them was marked as a LOBRO (good german OEM right?) and tree things were different about this one. Frist the cage had a slightly different shape for the openings (almost perfectly oval, while the other three pinched in in the middle of the opening), second, I had to drive the CV off the axle (vise, BFH, and a big drift) while the other three came off with just a little tap, and third, when all cleaned up and dry the lobro cv is much "looser" than the other three, I can manipulate the cage in and out, and take it apart very easily while the other three barely move now that they are together with no lube.
So, question, is this a "bad" cv? No cracks, looks like normal wear otherwise...I still have the axles on the car to pull, so I can probably find another good one, just wondering if I need to bother?
Thanks,
Tony (IMG:http://www.914world.com/bbs2/html/emoticons/type.gif)
cha914
post May 18 2005, 08:35 PM
Yep, couldn't resist the blue balls comment (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif)
at the rate I drive this car another 20k will be about 5 years...so that works for me...
Thanks again,
Tony
cha914   Rebuilding CV's ... when is a CV considered bad?   May 18 2005, 09:08 AM
SirAndy   sorry, can't help 'ya, but this question i...   May 18 2005, 11:38 AM
James Adams   Any radial play in the joint? Galling or pits in ...   May 18 2005, 11:43 AM
cha914   The wear on the joint looks similar to the other t...   May 18 2005, 12:52 PM
Mark Henry   Run your finger in the land where the ball travels...   May 18 2005, 01:06 PM
cha914   no blue balls here http://www.914w...   May 18 2005, 02:16 PM
cha914   Here are a couple pics of the lobro cv...   May 18 2005, 07:16 PM
cha914   and the inside lands...almost all of the cv's ...   May 18 2005, 07:17 PM
Mark Henry   I wondered who would make a blue balls crack! ...   May 18 2005, 07:42 PM
cha914   Yep, couldn't resist the blue balls comment <...   May 18 2005, 08:35 PM
RustyWa   Here's a sloppy one for you.   May 18 2005, 11:24 PM
mike_the_man   So if it's sloppy, what can be done? I'm ...   May 18 2005, 11:28 PM
Mark Henry   That s not that sloppy...I've seen them fallin...   May 19 2005, 05:48 AM
rdauenhauer   Another Good thread! Ok so speaking of Blue b...   May 19 2005, 10:02 AM
McMark   Mmmmmm, ceramics. Sweet, but $.   May 19 2005, 10:07 AM
Rotary'14     May 19 2005, 12:20 PM
- Lo-Fi Version Time is now: 7th July 2025 - 03:50 AM
