Intake length vs torque, Just anthoer carb question No boobs |
Joe Ricard |
May 18 2005, 02:03 PM
So I have short intakes and 44IDF's with 38mm vents
How long of an intake should I go to with these carbs or should I go to 40 IDF's with 32 vents or 28 vents. I have some longer runner intakes and the other carbs so it's just a matter of experimenting I guess. 2.0L Bus piston Web 86B portmatch intake and exhaust ports. 13lb flywheel Bursch SSI Car weighs 1965 lbs 205/50-15 Kumho V700 R tires. Thought of playing with spacers under the carbs to get more length and maybe spacer under the common length velocity stack. Looking for more torque down lower to pull harder exiting the apex of tight AX turns. Whose got the experience of really been there done that? great gains or don't bother. |
messix |
May 18 2005, 09:37 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
quick and dirty
big and short= high rpm power small and long= low rpm power this goes for the valves, head port and intake runner and carb or thottle body here is your power balacing act . intake, head ports, cam and exhust have to be matched to get max preformance. |
Lo-Fi Version | Time is now: 11th June 2024 - 12:44 AM |
